#11220 - 02/07/08 10:57 AM
GL freezing
Karen
Loc: Pine Brook, NJ
In GL after printing multiple batches and then posting them, I've had the screen freeze at the same point several times. Screen states "merging transactions". It then freezes. I have to press CTRL ALT Del to get out of the GL. When I get back in, I've always been able to print the posting journal, but I'm concerned as to why it may be happening. I also would like to know if there's some way to check, other than the posting journals, that the transactions are "merging" completely and correctly. Or, if there is a need to.
Thanks, karen
#11221 - 02/07/08 11:32 AM
Re: GL freezing
[Re: Karen]
Hello Karen,
Firstly, are we talking about Ledger V8.1 or Ledger V9.0?
Secondly, when you bring up the task manager, does it indicate that Ledger.EXE (or ALWIN.EXE) is "doing anything? You can check this by switching to the Processes tab and sorting by CPU usage. It's also helpful to add IO Read Bytes to the columns displayed (use View | Select columns in the Task Manager), since sometimes I/O intensive tasks (of which GL posting is one) can occasionaly be so busy reading and writing information that they "forget" to check the keyboard and mouse as frequently as they should. Also, if you have a "marginal" network card, posting in Adagio Ledger is I/O intensive enough it might be causing the card to fail.
BTW - I hope you are backing up frequently, and checking your data integrity daily. "Ending" an Adagio module while it's posting is a very bad idea.
#11260 - 02/11/08 04:31 PM
Re: GL freezing
[Re: Softrak Support]
Karen
Loc: Pine Brook, NJ
I am using Ledger V9.0
I just had it happen again. I suspect you are correct that the "posting complete" message is hidden under the merging transactions bar, as I can see a slight outline of another box behind it. I pressed the enter key and the "print posting journal" box appeared behind the "merging transactions" box. Pressed enter again and the message disappeared.
Is this a problem with my network card? Haven't had a problem with it, and it's relatively new. I back up all the time; however checking the data integrity is another story. Not done as frequently. Sorry Andrew, couldn't check in the task manager what was happening, because I followed the "click enter" instructions before checking.
If it's my card, I will get a new one. If it's something else that needs to be addressed, please let me know so I can look into it (have the proper person do that) immediately.
Best, Karen
#11267 - 02/11/08 06:00 PM
Re: GL freezing
Karen
Loc: Pine Brook, NJ
Version is 9.0A (080122)
Completed a data integrity check and it was fine. I will check my task manager when it happens again, and post what I find. I checked with our computer specialist and he thought our network card should be fine.
#11279 - 02/12/08 09:48 AM
Re: GL freezing
Karen
Loc: Pine Brook, NJ
Good Morning,
I am the only one using GL. It does not happen on all batch posts. I print batch listings first all the time, and have the option set that will not allow a post unless batch is printed.
I will be much more aware of my actions in GL, and will hopefully have more answers for you next time it happens. Thank you so much for taking such an interest in the problem!!
14625 Topics
