Page 1 of 3 1 2 3 >
#10376 - 11/28/07 03:05 PM Adagio Ledger V9.0A (080122) Service Pack
Updated Jan 29
This message is designed to keep you up to date about the recent release of Adagio Ledger V9.0A and any issues that are discovered that may affect you.
Another service pack has been released (Adagio Ledger V9.0A (080122)) that addresses issues identified in previous releases of this module. You can read all the details of this Service Pack in the Release Note.
We expect Adagio SalesAnalysis V8.1A to ship shortly.
Thanks for using Adagio.
Edited by Andrew Bates (01/29/08 08:25 PM)
#10617 - 12/31/07 08:16 AM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Retired_Guy]
Kevin Jenkins Offline
Adagio Graduate
Loc: Charlottetown, PE
Hi Andrew .... I previously installed 9.0 Ledger and had corrupted data while trying to post from our main terminal .... posting from my terminal works fine after your fine folks repaired the data ... I applied the latest 9.0 service pack hoping it would solve the posting issue, everything looked fine, I imported previous history great, no data integrity errors, but I find that I can't load the Financial Reporter .... I get an error "Unable to load Specification Designer (Error 0)".
Help .... it's Dec 31, and I can't print a financial statement of any kind!! Same error on other machines. The 8.1A ledger still works A-OK on non-converted data. Help!!!
#10618 - 12/31/07 10:31 AM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Kevin Jenkins]
Hi Kevin
I had a client with the same problem. It ended up being a problem with the file name LedgerFinRep.exe being longer than 8 characters, and it got saved somehow as Ledger~1.exe. If you see a file with the name Ledger~1.exe and no file named LedgerFinRep.exe in your \softrak\ledger folder, then that is the problem. Rename the file.
But it makes me wonder why this is happening, I thought it may have been a fluke when I saw this at my client.
#10627 - 12/31/07 01:41 PM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Steve Schwartz]
Hi Kevin,
I think Steve's post identified the problem. We'll take a look at how this might be occurring first thing in the new year.
Enjoy the impending snow storm, and Happy New Year!
Thanks for your patience.
#10667 - 01/04/08 06:59 PM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Retired_Guy]
Sammy Offline
Loc: Summerland, B.C. Canada
Andrew: I am attempting to install the service pack. "It" keeps telling me that the existing version is not found in the destination directory. I look and it is there. What am I doing wrong????
#10669 - 01/04/08 07:12 PM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Sammy]
Hello Sammy,
The service pack is expecting to update Adagio Ledger V9.0A - this is found in the \SOFTRAK\LEDGER subdirectory on whatever drive your Adagio is installed on.
Check carefully - and make sure your drive mapping are set up the way you expect.
Happy New Year!
#11007 - 01/29/08 08:27 PM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Retired_Guy]
Hello all,
There is a new Service Pack available for Ledger available on the web today. User announcements will be going out shortly. Details of the fixes can be found by reading the Release Note.
#11113 - 02/01/08 02:00 PM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Retired_Guy]
Sammy Offline
Andrew: I am trying again to update the Ledger. Although there is a "Ledger" subfile in Softrak the Ledger executes under ALWIN. I have tried both and it still says existing does not exist. I compared the directory mapping to the other modules which I have updated without a hitch. Is there something else?
#11114 - 02/01/08 02:26 PM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Sammy]
Hello Sammy,
Change the properties of your Adagio Ledger shortcut to point to \SOFTRAK\LEDGER\LEDGER.EXE if you want it to launch Adagio Lendger V9.0A. \SOFTRAK\ALWIN\ALWIN.EXE is Adagio Ledger V8.1A (or earlier).
#11118 - 02/01/08 02:43 PM Re: Adagio Ledger V9.0A (071219) Service Pack [Re: Retired_Guy]
Sammy Offline
Andrew:
Although there is a Ledger subfile in the Softrax folder there is no ledger.exe file. Have I missed the update from 8.1 to 9.0 or does this mean my update of the Lanpack 9.0 hasn't "taken"? I have been exploring to try and figure it out myself but the Lanpack upgrade is marked as installed and I do not remember having any problems. Should I retried installing that?
Page 1 of 3 1 2 3 >
2 registered (Tanya_Belanger, 1 invisible), 74 Guests and 1 Spider online.
