#10929 - 01/23/08 05:56 PM ledger 9 financials help
David Dearin Offline
Loc: Heffley Creek, BC
I am having a problem with a couple of formulas in a custom statement that previously worked in version 8 but now gives an error in 9.
I thought to look at the help files to see if the formula had changed or what, but the help screens are all blank,
The help screen from the ledger work fine.
Service pack was applied.
The first formula in question is =IF(F58==0,0,F58/F61) F58 is zero but the cell returns "Error!"
The second formula is =IF(F21,F50/F21,0) both F50 and F21 are zero and the formula returns 281.21%
David Dearin
#10930 - 01/23/08 06:05 PM Re: ledger 9 financials help [Re: David Dearin]
Hi David,
Division by zero is undefined (remember your algebra classes?).
SO:
Code:
should probably be:
Code:
=IF(F61==0,0,F58/F61)
Similarly:
Code:
=IF(F21,F50/F21,0)
should probably be:
Code:
=IF(F21<>0,F50/F21,0)
Make sense?
#10931 - 01/23/08 06:08 PM Re: ledger 9 financials help [Re: Retired_Guy]
Algebra? It graduated in the 60's Andrew. I have trouble remembering a lot of that time period...
LOL
David Dearin
#10932 - 01/23/08 06:13 PM Re: ledger 9 financials help [Re: David Dearin]
The first one worked. But the second one...
The symbols <> changed when I hit the enter key to !=
Is that Algebra?
David Dearin
#10933 - 01/23/08 06:17 PM Re: ledger 9 financials help [Re: David Dearin]
On the second one tried F21==0 and that worked.
Because the formulas worked in version 8 I guess Ledger 9 does better math than Ledger 8?
What about the help screen in financial reporter?
David Dearin
#10934 - 01/23/08 06:44 PM Re: ledger 9 financials help [Re: David Dearin]
Michael Mulrooney Offline
Dispatching the Help in the current 9.0 Financial Reporter is a known problem and will be addressed in the next service pack.
In the meantime create a shortcut on your desktop for the LedgerFinRep.chm file in ..\Softrak\Ledger
BTW <> and != both mean "not equal" to propeller heads
1 registered (Warren Karges), 117 Guests and 3 Spiders online.
14653 Topics
