#10678 - 01/07/08 05:22 PM Ledger Sample Data
Kay Offline
Loc: Fowler, CA, USA
I have never loaded the sample data. I need to load the Ledger Sample data to find out to Import a Batch of GL transactions. The Help screen refer's us to the Sample data.
Kay N. Paboojian, Jr.
#10680 - 01/07/08 05:51 PM Re: Ledger Sample Data [Re: Kay]
Hi, Kay,
Sample data uses an extension of .SAM
If you're using GL9.0, sample data is normally installed to x:\SOFTRAK\LEDGER\SAMDATA (where 'x' is the mapped drive that the program is installed on).
If you're using GL8.x, sample data is normally installed to the x:\SOFTRAK\ALWIN\SAMDATA folder (again, where 'x' is the mapped drive that the program is installed on).
When you open Adagio Ledger, simply change the data path and extension on the logon screen.
#10683 - 01/07/08 06:33 PM Re: Ledger Sample Data [Re: Softrak Support]
Kay Offline
Thank you for the response. The problem I was having was not finding the Sample data but how do I load the data on my system.
I researched further, found the answer, installed the SAMDATA, and found the sample spreadsheet I was looking for.
This issue is closed.
