#10623 - 12/31/07 11:25 AM Re: Adagio Ledger 9 Adagio Menu [Re: Steve Schwartz]
Hello Steve,
To add Ledger 90 to the Adagio menu for Checks, I had to make these changes to Menus.ini:
First, modify the Adagio section:
[Adagio]
GL=SSI Ledger 90
Then add these lines in a new section:
[SSI Ledger 90]
name=Adagio Ledger 90
data=none
program=d:\softrak\Ledger\Ledger.exe
Parameters=/u%u /p%p /d%d /e%e /t%t
Hint=Launch Ledger 90
Happy New Year!
#10670 - 01/05/08 09:49 AM Re: Adagio Ledger 9 Adagio Menu [Re: Softrak Support]
Hi again
Thanks, that worked!
Now I want to go the other direction. The company is using Payables 8.1A with Ledger 8.1A. They have Ledger 9.0A installed but are not ready to convert yet.
What do I have to add to the Menus.ini file so that Adagio Ledger 8.1A appears?
#10671 - 01/05/08 12:08 PM Re: Adagio Ledger 9 Adagio Menu [Re: Steve Schwartz]
Hi Steve,
The path for Ledger V8.1A is:
program=d:\softrak\alwin\alwin.exe
#10672 - 01/05/08 09:21 PM Re: Adagio Ledger 9 Adagio Menu [Re: Retired_Guy]
No, I need the full text. See the reply on 12/31 at 12:25PM for the syntax I need. For example, I never would have guessed that version 9.0 has to have the line "GL=SSI Ledger 90".
#10673 - 01/06/08 03:21 PM Re: Adagio Ledger 9 Adagio Menu [Re: Steve Schwartz]
OK Steve, but isn't it apparent that the tag to the right of the equals provides the name of the section to get the program name and other information?
[Adagio]
GL=SSI Ledger 81
[SSI Ledger 81]
name=Adagio Ledger 81
data=none
Hint=Launch Ledger 81
The new menu choice won't show if the EXE is not found.
#10687 - 01/07/08 08:19 PM Re: Adagio Ledger 9 Adagio Menu [Re: Retired_Guy]
Thanks Andrew, that worked.
I could have guessed it, but there are other options, starting with SSI Ledger 81A and SSI Ledger 8X. It's easier to ask, and besides it's useful for others to see it in writing.
1 registered (Bruce Gardner), 87 Guests and 0 Spiders online.
1865 Members
14511 Topics
27 28 29 30 31
