#10553 - 12/12/07 08:46 PM Ledger 9.0 update questions
Kay Offline
Loc: Fowler, CA, USA
I have not updated to 9.0 yet and maybe I am glad I have not done so yet. In the response about the HotFix a statement was made about retrieving from other products but one that was NOT mentioned was DOS Accpac. I still run DOS Accpac payroll (DSS) and Accpac Job Costing. If I upgrade to Ledger 9.0, is it still fully compatible with these older products? My plan is to migrate to a newer system by January 2009.
I could not understand the statements about the changes to Financial reporter but I have run into an incidious problem with the Financial reporter in 8.0D. I spelled the "link.field" in upper and lower case instead of dragging the descriptor to the report. Everything was spelled correctly except the case and I have been reporting incorrect data for over 9 months. I have now retyped everything and the reports are correct now.
Kay N. Paboojian, Jr.
#10554 - 12/12/07 11:11 PM Re: Ledger 9.0 update questions [Re: Kay]
Hello kay,
There should be no problems retrieving G/L batches from old ACCPAC Plus products in Ledger V9.0A - we have only had an intermittent report from some sites running Adagio 3rd party products.
regarding "Everything was spelled correctly except the case... causing a problem in the financial reporter. Something else was the problem - specification codes are not case sensitive. "gldata.m" and "gldata.M" and "GLDATA.m" and "GLDATA.M" will all return the same result. Perhaps you are referring to the account numbers?
Feel free to e-mail me the "before" and "after" statements and I'll take a look. I'll need a ZIP of the whole GL though, as the statements on their on won't mean much.
Thanks for using Adagio!
#10561 - 12/13/07 01:25 PM Re: Ledger 9.0 update questions [Re: Retired_Guy]
Kay Offline
I am glad to hear that there should be no problem with old DOS Accpac.
I do not have a copy of the old spec files, sorry it is too close to year end and I don't have time to work on it. As a long time programmer I agree that the case should not matter if programmed correctly. The fact that this text is in quotes could be a problem that I have experienced in the past. I assure you that all I did was bring up the account list and type exactly what was on the screen in the exact case and the report displayed correctly.
#10564 - 12/13/07 02:59 PM Re: Ledger 9.0 update questions [Re: Kay]
"account list" or "account data"?
I have verifid that the 4 possible case combinations of the specification do not change the result returned, so something else was changed (sometimes software is like that).
Glad it's all working fine for you now.
Andrew
