Dear Delta Dawn
Hi! If you are referring to the Posting "sequence" then there is no way to reset this number which is automatically generated by the program.
Even if you print and clear the Batch Status Report, the posting sequence will not be affected.
You may have to complete your AR Year End first before this will take effect. I tried testing it here, but I am having problems with the older QIWIN release and am not getting the consistent results I was hoping for.
If completion of your AR year end does not affect the posting sequences in QIWIN, then it is likely something that cannot be changed.
I will have a firm answer for you after I am up and running again.
