#10262 - 11/15/07 12:34 PM Missing sample reports in Financial Reporter
Lulu Kauffman Offline
Loc: Maryland
I cannot find the budget forecast report in Financial Reporter. In fact I'm unable to find the sample data file. If for some reason these were not loaded when my IT dept installed 8.1, how can get them now?
#10264 - 11/15/07 01:52 PM Re: Missing sample reports in Financial Reporter [Re: Lulu Kauffman]
Hi Lulu:
Look in the Softrak\ALWIN\Samdata folder. Look for the GL!*.sam files. Copy & paste them to your live data folder. Rename the file extensions on those files from .sam to match your own file extension. This can be done one-by-one in Windows Explorer by highlighting each one individually & pressing F2.
If you are working in a LAN environment, the Softrak folder will be located on a drive letter that points to the server. If you are standalone, it is likely located on your C: drive.
If this doesn't work, please re-post to let us know.
#10312 - 11/20/07 10:58 PM Re: Missing sample reports in Financial Reporter [Re: Bruce Gardner]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
If you're not comfortable with the copying and renaming directly in windows, this can be done from within the Adagio Financial Reporter (FR) as well.
Choose File | Import Spec... You'll still need to browse to the ...\Softrak\ALwin\SamData installation folder but once you find the spec and click open, the FR will open the spec for editing right away. When you save it should default to saving in your data folder with the correct extension.
If the sample data is missing entirely, re-install the Ledger and select the sample data for installation.
Peter Banfield
BAMPH Consulting Services
Barbados
0 registered (), 192 Guests and 1 Spider online.
14672 Topics
