Hi Anthony,
ICPOD'I was the index file used for IC purchase orders for version 6.1B. This was changed to ICPOD'1 and ICPOD'2 for IC version 6.5A.
What I think this means is that your report is still based on the IC6.1B table, and is looking for a file that really doesn't have to be there. In testing this, I created a new report using the IC65A table, and deleted my ICPOD'I file beforehand. I was able to print successfully a report with Purchase Order header and detail fields.
What you should do is print out the report definition of this report (from the Print/Export menu). At the top of the first page will indicate the program and version. Does it say Inventory Control 6.5A or Inventory Control 6.1B? If it is the latter, you have to do a cross-table conversion for this report (and all others based on IC61B) to bring it up to the current level.
From Options, go to Configure and set Convert Reports to Yes. Also go to Install Data and make sure the Inventory Control 6.5A table is selected. Then open your report again. You should get a message to convert your report, which you should do, then save. Afterwards, set the Convert Reports option back to No.
Softrak Support
