Hi again, Dave
You never said what version of the CRPE32.DLL was actually in your Windows\System32 folder - was it the 7.0 version?
There is definitely something on your station that is preventing Adagio from 'finding' the CRPE32.DLL as it should. Since you copied/pasted the correct one from the Softrak\System folder - we know that the file should be there now.
Are you logged into the system as a different User than normal, or have the priveledges or any other settings for this User changed since the last time you were able to print this report?
Have you tried rebooting your station?
Can you print other reports from the main Payables Reports menu? I wouldn't expect so, due to the nature of the message.
Is Adagio installed on a network Server, or standalone on your PC?
SERVER
If Adagio is installed on a Server, then I would suggest running the workstation setup again on your station to have it re-install all the necessary reporting files. Information on how to do this can be found in the main Adagio Fundamentals Guide.
To further test this theory, you could quickly try printing the report from another station. I would be surprised if another station had the same problem.
STANDALONE
If Adagio is only installed on your station, then re-install the program to see if this helps.
Regards
