Hi Ken
Has this been happening from day one, or has it just started to occur? Has anything changed regarding your invoice specifications?
I would suggest a process of elimination:
1. Try performing the same process in Sample Data (Softrak\QIWIN\Samdata) using one of the sample specifications - what are the results? If you cannot duplicate it in sample data, then it could be something to do with your specification...
2. Copy a specification from the QIWIN\Samdata sample data directory into your data directory, change the .sam extension to be the same as your data extension, and try printing using that - does it work ok? If this worked, then it's not your data and it's not the program - it would seem that your invoice specification needs to be modified, or perhaps it has become damaged and thus unuseable. If this is the case, you may need to find a copy of it from a previous backup of your data where you know it worked ok, and copy this to your data directory, replacing the defective one.
It seems the program is processing the data the way it should, so there should be no worries there.
This sounds very familiar, but I could not find any notes on it for Adagio Invoices to see what the problem was.
If I come up with something in the meantime, I'll post another message here.
Regards
