Hi Bruce,
I ran a data integrity check and everything is okay. I know this worked last year and the year before. I still have my .csv that I used the past 2 years. Is anyone able to import pick sequences anymore?
I tried it with overwrite records checked, add new records unchecked and only 2 columns in the file (item code, picking sequence). I removed all default fields and used only field selections for Item Code and Picking Sequence. Validation is good then, "Record locking - Unable to access record in I/C Item Master. This record is in use by [symbols] in window [symbols].
ICIMPERR.DAT says, "Record 21 with key AN244A ignored because 'add new records?' is turned off".
Now why would it want to add it as a new record?
Our item codes are have 2 characters a space then a bunch more characters. In the past, I've never used the space. Maybe I need the space?
Is it just me that can't import items anymore?
