Hi Mabel,
API0002.ARF sounds like a temporary file that Adagio Payables creates in the data directory. Could the complete file name be API0002T.ARF? Or another? The exact file name would be needed to fully determine what may have happened.
If so, the likely reason for the error is that the temp file was created the last time a report was printed or a batch posted, and not cleared correctly when done. Perhaps the file was left locked on the server and Adagio could not delete it whe it was finished.
First, do an Integrity Check. Then backup your AP data. If clean, then rename the data file in question and try again with the DIC.
The cause is likely what Steve suggested. You probably shouldn't have to re-install the program. IF any of these steps are not something you are comforatable with, I also recommend contacting your Adagio consultant.
