Hi Edward,
Just a few notes:
<1> I'm not quite sure why he did it, but I don't believe that the "Cat" prefix that Andrew used in the actual list in the NamedItems text file "CatList.GVNames" in his demo example is "required". Now don't get me wrong, it is required due to the way he has configured the demo, I just did not want you to think that the prefix was a requirement in all uses of this function. Not that you would have thought that but some might.
<2> You'll definitely want to use the /n parameter but bear in mind that updating the text file and refreshing the loaded list during a GV session will not be totally automatic/dynamic so the users may need to be aware of this.
<3> Because of item <2> the questions raised above as to how often the IC categories have to be updated/maintained would be quite important to the effectiveness of the solution
Pete
