#9930 - 10/01/07 02:15 PM
Rate Type
Adagio Prodigy
Loc: Langley
We recently went through a complete set of number changes in our Ledger, using the KOM number changer. After completion of these number changes, I went through each subledger and changed all of the default numbers.
Everything seems to be working fine, EXCEPT for inventory adjustments. When these are retrieved to the ledger, they have a rate type on them of "SP" which does not exist in our system. The only rate type we have is "AV"
As mentioned, this is only happening for the Inventory module. I cannot see in Inventory WHERE to change this. Any help you would be able to provide would be wonderful. Thank you.
#9932 - 10/01/07 05:42 PM
Re: Rate Type
[Re: Softrak Support]
Adagio Prodigy
Loc: Langley
Actually, the rate type in Inventory is set at "AV", so I am unsure where the heck the "SP" is coming from. Sorry to lead you astray, the Profile was the FIRST place I checked!
#9934 - 10/01/07 06:49 PM
Re: Rate Type
Adagio Prodigy
Loc: Langley
1) Yes, we are using Multicurrency. 2) IC Adjustments are the ones showing up most frequently with the "SP" rate. IC Adjustments are new, only created the day they are entered. 3) "SP" I do recall showing up before, it had something to do with our merging three data bases in to one.
I cannot remember how we fixed this, or really how the original problem occured when we merged our data bases, but I do remember the "SP".
Is there anywhere other than Profile that I can look? I have checked all modules, and cannot find the "SP" anywhere. Very frustrating. Also, all existing Purchase Orders now have the incorrect default accounts on them. Is there any way to change this, other than deleting all purchase orders and reentering?
Thank you.
#9938 - 10/02/07 09:44 AM
Re: Rate Type
Adagio Prodigy
Loc: Langley
Hmmm, okay if I curse? I have been able to find a way to change the batches once they are retrieved to the ledger, so they can be posted correctly, but it is entirely tedious and completely cumbersome.
Any idea when this may be fixed?
Also, there was the question, not sure you can help, (I know Purchase Orders is not a Softrak module), but there is a problem of existing PO's with incorrect default ledger account numbers. Is there a way to change the "old" defaults on existing PO's to the new numbers without deleting and re-entering Purchase Orders?
Thank you for answering.
#9939 - 10/02/07 11:30 AM
Re: Rate Type
[Re: Barb9]
Hi Barb,
Thanks for noticing this problem in Inventory. If you are not using the SP rate, why not make its rules identical to the AV rate as a workaround until the problem is fixed.
#9947 - 10/02/07 06:17 PM
Re: Rate Type
[Re: Retired_Guy]
Loc: langley
thanks Andrew we will try it as a work around. Bruce
#9955 - 10/03/07 05:27 PM
Re: Rate Type
[Re: Bruce]
Adagio Prodigy
Loc: Langley
We noticed today that the same problem is occuring when we use A/P Manual Checks. Could you please look at this in your sample data as well, just to ensure that it is not our error?
Thank you.
0 registered (),
140
Guests and
2
Spiders online. |
14578 Topics
