#100 - 06/21/99 03:50 PM Re: Subscript error in QR 6.5A
Hi John,
To verify just how large the data in the item number field is, use the Count(field) function in a formula (in the detail section) to verify the lengths of the item numbers. My guess is that one item in the data set has a length of less than 6 characters, thus causing the problem. You could also create a formula to label all of the records where this is true [If count(Item number)<6 then...].
When you determine the item number causing the problem, you will either have to modify your formula with the subscript to incorporate this data, or create a selection formula to dis-allow item numbers <6.
You probably should temporarily delete this formula while testing this out, so that the report can print.
#101 - 06/21/99 04:55 PM Re: Subscript error in QR 6.5A
If you have different length item numbers you can pad the formula with spaces and still use the subscript function.
E.g. (String + " ")[1 to 3] should always work even if String only has 2 characters, of course the third character returned will be one of your 'pad' characters.
0 registered (), 128 Guests and 6 Spiders online.
1869 Members
14602 Topics
