Dear Rob
Thanks for being so descriptive in all of your posts...it helps us to give complete responses.
Yes, if you try to create an Adagio Receivables' dataset that has TBR DOS data in it, you will get the message "TBR data was found. Use Time and Billing program to convert it.".
Yes, if you convert the TBR data to TBWIN it will create Adagio TB & A/R data.
You will not have to remove the TBR DOS data because, if you choose to open this TBR DOS dataset with TBWIN, once it has been converted, TBWIN will remove (delete) all existing TBR DOS data files. Therefore, if you want to retain these files, I would suggest taking a copy of the DOS dataset and keeping it in another directory (if you need to access it for any reason) PRIOR to converting the dataset.
Just as you have ACCPAC Plus "companies" that use TBR DOS and/or other applications and some that do not, if you wish to use TBWIN for some "companies" and not for others, because these companies will either reside in different data directories and/or have different data extensions, it should not cause a problem.
Softrak Support
[This message has been edited by Softrak Support (edited 03-21-2001).]
