#8974 - 05/08/07 12:36 PM GL Deleted Batch
bal Offline
Adagio Ace
Loc: Ottawa
I accidentally deleted a GL Batch and I was wondering if there is anyway to recover it. I have the batch since I back up daily and I know the easiest thing would probably be to recreate the whole thing but it's a batch with a lot of transactions.
I tried to "unpost" it but of course it was never posted so....
#8978 - 05/08/07 07:49 PM Re: GL Deleted Batch [Re: bal]
Hi bal
Restore the GL from backup to a different folder. Then launch GL pointed at that folder. You should see the open batch.
Archive the batch under Maintenance | Maintain Archive Batches. The name is unimportant, but remember it. Then exit the backup GL.
Launch the live GL. Go into Maintenance | Maintain Archive Batches and change the Archive batch path to the backup folder. Restore the batch using the name above.
#8979 - 05/09/07 08:33 AM Re: GL Deleted Batch [Re: Steve Schwartz]
bal Offline
Adagio Ace
Loc: Ottawa
I didn't realize you could restore an archived batch from a different dataset.
Thank you, thank you, thank you. You have saved me a ton of typing.
I could see the batch in Gridview so I was wondering about exporting the batch from Gridview into Excel, then importing the batch into the ledger.
Would that way work too? (Your way is a lot better.)
Just by the way, the deletion happened because I thought I was deleting a column in the batch view. It seems easier to delete than to restore.
Since you can unpost a batch, I think it would be good to be able to "undelete" too.
Thanks again.
#8980 - 05/09/07 08:45 AM Re: GL Deleted Batch [Re: bal]
Hi bal,
I'm sure that you've remembered by now that you nee to double-click on the column headings to edit the fields in the grid.
Ledger does ask "Are you sure you want to delete this batch?" before it actually does the deletion. I guess we really need to ask "Are you really sure?"!
Glad you're back to the races...
#8983 - 05/09/07 10:24 AM Re: GL Deleted Batch [Re: Retired_Guy]
bal Offline
Adagio Ace
Loc: Ottawa
Yes.
Are you REALLY, REALLY sure?
Maybe two warnings would be nice but an easy way to reverse the deletion would be even better.
I find the editing of column headings a little troublesome. I don't often change the display so I single click, then because it seems to be responding slowly, I keep clicking!
I've had Adagio for a very long time and this is the first time I've mistakenly deleted a batch and now I have a fix so I'm a happy camper!
0 registered (), 259 Guests and 3 Spiders online.
14622 Topics
