Hi:
If page breaks are your only need, then edit the existing report. In general, the steps are:
-Locate OECOMM.rpt in the OEWIN\StandardRP folder
-Make a Backup copy of it
-Edit the original
-Locate the Salesperson header section/band (Group Header 1)
-Chose Format Section
-Put a check-mark on "New Page Before"
-Save the changes
-Test the report from Order Entry
-If you like the results, make a copy of the completed file
The last step is important because every time you install a Service Pack there is a chance that it will contain a new Commission Report and therefore over-write your changes. If so, you either copy your modified file back or make the same changes to the new, improved version.
Tech Support may have a suggestion about handling that situation better.
Finally, I have to add the warning that Crystal Reports is a complex tool so make sure you are comfortable with it before making extensive changes.
