#8825 - 04/09/07 10:54 AM
Order Action Template
When I came in this morning the DataCare Integrity report had an error message on the Order Action Template Header that it failed. When I try to go into the Order Action Report a message comes up that the report was not found. I then tried to create the report, another error came up 4102 occured when attempting to append record O/E Order Action Template Header. On the order action template menu, the Rep Report shows up 3 times plus an Order Action Default. When I select the default, it changes to Rep Report which the system is telling me that it's not found. I must have somehow changed that default. My question is after running DataCare if I rebuild, will that take care of the problem on this Template?
Thank you, Orlanda
#8826 - 04/09/07 11:18 AM
Re: Order Action Template
[Re: ]
Hello Orlanda,
In Order Entry, make a backup of all your data. Then run the Data Integrity Check in OrderEntry, and select "Rebuild" if it finds any errors. If the DIC fixed errors, run it again until it reports no errors, or only errors that can be fixed by the operator. You may need to re-create the report.
#8861 - 04/18/07 03:23 PM
[Re: Retired_Guy]
Casual
Loc: toronto
When I run period -end for A/P, the message says: Invoice posting journal-should print & clear first, Manual Check posting-should print & clear first, Adjustment posting journal-should print & clear first. How can I clear them? which one should I select to clear them?
#8888 - 04/26/07 03:23 PM
[Re: Softrak Support]
Casual
Loc: toronto
When the Print Invoice Posting Journal completed, the message appears: Do you want to clear posting journal for the range specified? Yes No. Which one should I select? Yes or No? If some invoices were posted, but not paid. we are going to pay them in new fiscal year. Should I still selct Yes? and Will all unpaid invoices carry forward to the new fiscal year?
0 registered (),
127
Guests and
2
Spiders online. |
