#8667 - 03/16/07 11:38 AM Cost Variance
I have an issue that I can not seem to resolve.
We just started using the Adagio OE to enter orders. My problem was that since these orders were entered and then invoiced in ACCPAC we have a Cost Variance that is wayyyy out of whack.
We use standard costing and our standard cost for the item was 5.20 and the most recent cost was 5.20. We posted 2300 and got a cost variance 27,496,040.00.
77021- LA 2,300 4026 16,100.00 *
11,960.00
5210 27,496,040.00
PLANTER BUCKET ST 2 LAVENDER EMBOS 1205 27,508,000.00
Can anyone help explain how this could happen.
mp
#8668 - 03/16/07 12:33 PM Re: Cost Variance [Re: ]
Hello Mauricio,
The first question is - who did Dayend, Adagio or ACCPAC? (Also what versions and service packs etc.)
The cost variance account is hit with the difference between the standard cost and average cost for an item when dayend is run. Next is - who touched the average cost? This figure is affected by receipt of goods (Inventory or Purchase Orders) and adjustments (or less likely by a credit note in OrderEntry returning goods to inventory). What is the average cost for this item? When did it change? (Print some of the inventory history reports to see what's been going on with the item.)
#8711 - 03/22/07 12:28 PM Re: Cost Variance [Re: Retired_Guy]
The Dayend was done in Adagio. I know the orders were entered in Adagio but were invoiced in ACCPAC.
The average cost for the item is : 5.20
and the standard cost: 5.20
Adagio Inventory 8.0b(061010)
Adagio Order Entry 8.0A (060510)
This particular item was an item that we have only three transactions on and here they are:
07/01/31 10473 77021- OE KIR -2,300 23,000.00 5532 11,960.00
Shipment PLANTER BUCKET ST 2 LAVENDER LA EA 5210 1205 -11,960. 0.00
07/02/21 60 77021- IC FG 2,300 2020 -11,960.00
Receipt PLANTER BUCKET ST 2 LAVENDER LA EA 1205 11,960.00
07/03/15 10561 77021- OE FG -2,300 16,100.00 5005 11,960.00
TRKIRK Shipment PLANTER BUCKET ST 2 LAVENDER LA EA 5210 1205 27,496,0 -27,508,000.
39,100.00 11,960.00 -27,484, -27,496,040.
* Note: Extended may be AP Clearing, Adjustment WriteOff, Cost of Sale, J/C Clearing or Assembly Cost amount.
3 transaction(s) printed.
Edited by Mauricio (03/22/07 12:30 PM)
#8712 - 03/22/07 12:39 PM Re: Cost Variance [Re: ]
Hi Mauricio,
The first shipment predates any receipt, so it's average cost would be $0.00. Then you received some into inventory (which will calculate an average cost). Then you shipped some more. Is that right?
It's hard to read the transactions because of wrapping and alignment. Try using the {code} {/code} tags to keep the spacing as you type the numbers. You replace the "{" with "[" brackets to use the special tags.
#8716 - 03/22/07 02:22 PM Re: Cost Variance [Re: Retired_Guy]
You are correct that the average cost would have been 0.00 when we first shipped. We then received the exact amount that we had originally shipped.
Later we shipped the same amount and for some reason the costing was overstated. As you can see by the reciept it was received at the correct cost. 11,960/2300 = 5.20 and our standard cost is 5.20.
btw I now have another invoice that did the same thing. This invoice was entered into ACCPAC, invoiced in ACCPAC and Day end ran in ACCPAC. I have never seen this happen before.
Mauricio
Code:
#8724 - 03/22/07 04:26 PM Re: Cost Variance [Re: ]
Hi Mauricio,
The simple answer is - Don't let inventory go negative. There's an option in the company profile to prevent this.
I think the average cost amount would have been messed up when you posted the receipt, since you'd then have 0 on hand with a cost of 11,960.
You then ship 2300 at what I think would work out to infinite cost. Someone more familiar with what's going on in this case will probably correct me.
#8738 - 03/23/07 10:37 AM Re: Cost Variance [Re: Retired_Guy]
Andrew,
I have been at this company for 8 years and we ALWAYS have let items go to negative. We have never seen this problem.
btw the other instance that I reported we found was correct. The average cost was at 120 and standard at 0 so in essence we created that problem.
The instance originally reported can not be explained. Other than we used Adagio.
We are tracking our costing now when it hits the GL so we can reverse the erroneous entries. I will keep you abreast of my progress uncovering the problem.
mp
#8740 - 03/23/07 11:12 AM Re: Cost Variance [Re: ]
Hi Mauricio,
I think you'll find that Adagio Inventory and OrderEntry doesn't have anything to do with this. One of the invoices you mention was processed completely in ACCPAC.
Are you using Purchase Orders for Adagio?
#8742 - 03/23/07 01:23 PM Re: Cost Variance [Re: Retired_Guy]
Andrew,
The one that was completely in ACCPAC was correct. Our average cost was 120 and our standard cost was 0.
We have PO installed but are not using it.
mp
#8743 - 03/23/07 01:29 PM Re: Cost Variance [Re: ]
Hi Mauricio,
Did the one done completely in ACCPAC follow the same pattern? (Sold before any receipt, then receipted, then more sold?)
1 registered (Tanya_Belanger), 225 Guests and 4 Spiders online.
14589 Topics
February
