#8332 - 01/31/07 03:16 PM AR 8.0B (061213) Problem with Distributions
I've just upgraded a client from AR 6.8A(020125) to AR 8.0B(061213). We have tax distributions created to track our ABST (new VAT) implemented on Monday. However, after the upgrade yesterday, it appears the "Acct/Dept" field has been made mandatory. The user is unable to exit the distribution edit mode unless an account code is entered, or the change is cancelled. In versions prior to (061213) the account code was not mandatory and as such we are able to use 1 tax distribution for multiple sales. Is this a glitch?
#8333 - 01/31/07 03:33 PM Re: AR 8.0B (061213) Problem with Distributions [Re: GT]
Hi PwC,
Yes I see that if you attempt to edit or create a distribution code in AR8.0B and leave the account field blank, the program will not let you save this - an account code is required. In version 8.0A of Adagio Receivables, you could save a distribution code without a valid account.
This might have something to do with the addition of Recurring Charges to version 8.0B, which also work with Distribution Codes. We can forward this to development.
#8338 - 02/01/07 08:31 AM Re: AR 8.0B (061213) Problem with Distributions [Re: Softrak Support]
Much Thanks,
We've found a temporary work-around, and will use it until the fix is released.
Edited by PwC (02/01/07 08:34 AM)
0 registered (), 189 Guests and 3 Spiders online.
14673 Topics
