#8303 - 01/26/07 01:48 PM Re: Payables 8.04 [Re: ]
OK - it appears to be data related.
How about making a backup of your data, running the integrity check and selecting Rebuild and then running the integrity check again.
You should make a note to check out anything that is "fixed" during the rebuild process.
#8305 - 01/26/07 07:14 PM Re: Payables 8.04 [Re: Retired_Guy]
Thank you Andrew.
I will tackle this tomorrow (Sat) and post up the results.
Cheers, JK
#8306 - 01/26/07 08:33 PM Re: Payables 8.04 [Re: ]
Hi JK,
Start a new thread if you need more help.
#8307 - 01/26/07 10:04 PM Re: Payables 8.04 [Re: ]
Hi JK:
At this point your choices are:
1) Rebuild: After you are told that the Integrity Check fails, you will see a "Rebuild" button available on that screen. It will try to repair the damaged data. If it completes successfully, immediately run Data Integrity Check again then check the key reports. NOTE: YOU MUST BACKUP YOUR DATA BEFORE RUNNING A REBUILD.
2) Restore: Using your backups, restore the most recent good dataset. Copy then delete the current files first. Then re-enter any entries made since then. If you are uncertain which files to restore, talk with your Adagio reseller.
3) Data Repair: Send your data to Softrak. They can fix the data. This is a billable service.
#8308 - 01/27/07 01:59 PM Re: Payables 8.04 [Re: Retired_Guy]
Originally Posted By: Andrew Bates
Hi JK,
Thank you Andrew for your assistance.
Cheers, JK!
0 registered (), 80 Guests and 1 Spider online.
14527 Topics
