#817 - 12/12/00 01:26 PM Vendors
Thanks for the previous help, my date field is now fixed.
While trying to find vendors in my vendor list I have found many duplicate entries and I am wondering if there is a way to merge the vendor information?
Also, I am wondering if there is a way to search when looking for a vendor? I can only search my vendor number, not by vendor name. Since my vendor list has no order to it, it is a very difficult and time consuming search. I have discovered if you are printing a report you can set it up by vendor name, so I often use the print preview function to find the organization I need. Is there an easier way or a setting I can change to try and fix up my list to make it more effective to use??
Erin
#818 - 12/13/00 03:14 AM Re: Vendors
Hello, Erin
There is no option or function to automatically merge one Vendor's transactions and information into another existing Vendor's file.
What you can do, however (after making a good backup of your qc datafiles) is to manually edit the Vendor Statistics of the Vendor you wish to keep active to reflect the new YTD information as it would be if you added the duplicate Vendors' stats together. Once you are happy that the figures are correct, you can then delete the duplicate Vendors from QCWIN.
To be able to search by other criteria besides the Vendor Name, you can press <F6> to access the detailed Finder. You can also change the columns displayed in this finder to allow for your specific needs by double-clicking on one of the column headings to access the QCWIN Column Editor.
Hope this helps!
0 registered (), 238 Guests and 2 Spiders online.
14655 Topics
