#7572 - 09/21/06 12:06 PM Print Fax Queue Listing
Fong Offline
Adagio Ace
Can not print the listing. Help!
#7573 - 09/21/06 12:19 PM Re: Print Fax Queue Listing
Check the ranges you are selecting on the Fax Queue Listing dialog.
#7574 - 09/21/06 01:34 PM Re: Print Fax Queue Listing
Fong Offline
Adagio Ace
Same old ranges we've been using the last 2 years.
#7575 - 09/21/06 02:20 PM Re: Print Fax Queue Listing
OK.
What do you mean by "cannot print". Do you get a message? Does it appear to try to print? Have you tried a different workstation? Can you print from the sample data? Can you print the company profile?
#7576 - 09/21/06 02:48 PM Re: Print Fax Queue Listing
Fong Offline
Adagio Ace
Yes, a message says printing fax queue and it appears to try to print. I have tried different workstations. No problem printing company profile. Only happens in one data set(OE). Can't find sample data. Thanks for the reply Andrew.
#7577 - 09/21/06 04:52 PM Re: Print Fax Queue Listing
Does anything come out on the printer? An empty page?
#7578 - 09/21/06 05:30 PM Re: Print Fax Queue Listing
Can you 'Print Preview' the fax queue report successfully? This can help identify the problem based on the results.
Also make sure than none of your ranges are from 'blank' to 'blank' but rather 'blank' to ZZZZZZ. And all the checkboxes selected too.
Has this worked for you before? It appears it has as you mentioned using the same ranges for the lat 2 years. The report is unchanged since 2004.
I assume this is when printing the fax listing from within OrderEntry. Do you get the same thing happening if you print the fax queue listing from Receivables for the same data? The fax information is shared across all applications for the data set.
Perhaps run CHKSYS.EXE on the workstation having the problem - maybe the wrong report tables are being read and this utility (found in the \softrak\system where the Adagio programs are installed) will determine this.
#7579 - 09/21/06 07:56 PM Re: Print Fax Queue Listing
Fong Offline
Adagio Ace
Nothing at all.
#7580 - 09/21/06 09:21 PM Re: Print Fax Queue Listing
Are you sure there's something to print? Can you print in from OrderEntry? or Receivables (they list the same queue)?
#7581 - 09/22/06 09:40 AM Re: Print Fax Queue Listing
Fong Offline
Adagio Ace
No.
14617 Topics
