#74 - 05/24/99 10:10 AM Quick Report 6.2a Dos - Sorting Report
Have been having problems with printing reports on some workstations where the reports get stuck at Sorting Report Data Stage.
This occurs on various W/stations irrespective of their indiviual operating systems or RAM capacity. Most are on Win95 rest on Win 3.11 or DOS. We are on Novell 4.11 Network. Thank you.
#75 - 05/25/99 01:40 PM Re: Quick Report 6.2a Dos - Sorting Report
I would suggest, as a test, copying your data to a local drive (C and try printing the report. It might have something to do with the Novell network and specifically Novell Client 32 if you have that.
If this is Quik Reports for DOS, then also check the available conventional memory (below 640K) as this is what Quik Reports requires in running. Depending on the report, you need a minimum of 530K of free memory, and more as the complexity of the report increases.
If you do have a newer version of Novell Client 32 and Quik Reports for DOS version 6.5A, and you have registered with us, you can contact your dealer to receive a ptf that will help in running Quik Reports under Novell.
[This message has been edited by Andrew Bates (edited 05-26-99).]
3 registered (Softrak Support, Warren Karges, 1 invisible), 156 Guests and 2 Spiders online.
14668 Topics
