#7223 - 07/12/06 01:43 PM Re: AP check printing
Is the issue that you want check printing to collate differently for a multi-copy, multi-page form? If this is the case, then Adagio does not give options for collating the copies of the different pages.
Should collating the other way be desired, then turn off the multi-copy part of the Adagio spec (ie number of copies = 1), and set the printer driver to print 3 copies. You gain control over collation, but lose the ability of printing specific information on specific copies. This decision of what is more important is up to you to make.
#7225 - 07/12/06 04:38 PM Re: AP check printing
Hello CACS,
The order that Payables prints is all pages for the first copy and then all pages for the second copy.
For example:
Copy 1, page 1
Copy 1, page 2
Copy 2, page 1
Copy 2, page 2
#7226 - 07/12/06 04:53 PM Re: AP check printing
Take a look at PrintBoss (www.wellspringsoftware.com). You can output to multiple trays with the push of one button.
#7228 - 09/13/06 06:24 PM Re: AP check design
chacamaty Offline
Adagio Groupie
I'm trying to use Wellspring blank check stock. The advice portions align correctly. However, I can't get the "check" portion, especially the MICR to print low enough on the check stock. If I select the "check" info and move down, it doesn't align the way I expect it to. I'm finding the check design software very confusing.
#7230 - 09/29/06 07:26 PM Re: AP check design
Have you tried using one of the specifications from the sample data, or perhaps one of the specifications that are shipped as templates with the latest release?
That might give you a clearer idea of how the various sections and fields work.
2 registered (Brian_Shead, 1 invisible), 844 Guests and 9 Spiders online.
14568 Topics
