#7208 - 07/12/06 12:50 PM AP Groups Set up and "Rights"
Karen Offline
Karen
Loc: Pine Brook, NJ
I have set up a user group in AP that allows those assigned to it, to enter our vendor invoices. I do not want them to have access to sensitive information in AP, therefore their access is quite limited. I would like to have the same personnel check our vendor statements against their invoices that have been inputed; however there are vendors that the details of invoices and payments should not be made widely available. ie: distributions, bonuses. How can I give them access to "some" vendor transactions and not "all"? Is there something in the vendor's profiles that I can check or input that would make them password sensitive, or perhaps in a separate "group"?
Thanks in advance for your time,
Karen
Edited by Karen (07/12/06 01:08 PM)
#7209 - 07/12/06 01:27 PM Re: AP Groups Set up and "Rights"
Hi Karen,
In Adagio, if you give a user security access to a particular function, they have full access to the information within. You cannot limit which transactions appear for particular users.
The answer to this question would be to use GridView to create a custom inquiry into the Vendor Transaction file for the user(s). It can be created uneditable so they cannot change which transactions are displayed on screen, only those you deem available.
GridView views can be attached directly within Adagio as a custom Inquiry, meaning all they have to do is find their vendor transaction lookup on the Inquiries menu.
#7210 - 07/12/06 01:36 PM Re: AP Groups Set up and "Rights"
Karen Offline
Karen
Loc: Pine Brook, NJ
I know the Gridview report would be available as a "view" in AR- what about in AP? They don't have any other modules available to them, other than AP.
#7211 - 07/12/06 04:18 PM Re: AP Groups Set up and "Rights"
Hello Karen,
Custom views for Payables are set up in a similar manner as the ones for Receivables.
Because they are specific to a program, the Payables users will only see the views set up for Payables.
#7212 - 07/13/06 12:45 PM Re: AP Groups Set up and "Rights"
Karen Offline
Karen
Loc: Pine Brook, NJ
Okay, I set up a gridview file that is now in AP, HOWEVER, even with the filter set up restricting vendors, simply toggling the filter allows ALL vendors to be visible. What do I do now?
#7213 - 07/13/06 03:17 PM Re: AP Groups Set up and "Rights"
Karen:
When you set up a User in Adagio, in addition to Code, Name, Password etc., you have a checkmark labelled "Edit GidView". Remove that checkmark for the users in question. They will not be able to change the Filter.
Note: i) this setting will apply across all modules for that User, ii) I don't believe the setting was available versions older than 8.0.
#7214 - 07/13/06 03:27 PM Re: AP Groups Set up and "Rights"
Karen Offline
Karen
Loc: Pine Brook, NJ
Bruce, that was already done. No checkmark for gridview. We have the most current version, however, they are still able to "toggle" the filter on and off. They can't actually change what I've created as a filter, but they can turn it on and off. Filter "off" is the problem.
I appreciate your trying to help!
Edited by Karen (07/13/06 03:28 PM)
#7215 - 07/14/06 12:16 PM Re: AP Groups Set up and "Rights"
Karen Offline
Karen
Loc: Pine Brook, NJ
Any other suggestions?
Again, in advance, thanks!
#7216 - 07/14/06 01:09 PM Re: AP Groups Set up and "Rights"
Lars Offline
Loc: Vernon, B. C.
I have a similar situation where filters are set up for users to view specific accounts in the Ledger. However, they can toggle off the filter and view all the accounts in the Ledger which is very problematic for this particular First Nations organization. (I'm hoping the users don't discover the filter toggle ). I'd like to see the filter button greyed out if the user doesn't have the view creation rights. Would this be possible?
Lars
Lars Glimhagen
Adagio Certified Trainer
Email: lars@lng.bc.ca
#7217 - 07/14/06 03:40 PM Re: AP Groups Set up and "Rights"
Toolbars are customizable, so you can remove the 'Toggle Filter' button from the toolbar. And of course when you launch GridView without Edit rights, you can't put it back on. This effectively prevents usage of Toggle Filter.
Load GridView with Edit rights. From the View menu, pick Customize. Go to the Commands screen. Make sure the 'File' list of buttons is selected - it is by default. Now left-click drag the Toggle Filter button from the toolbar and drop it onto this Commands screen. For this user, the toggle filter button will now be gone from the top.
It seems reasonable to have this function inactive when Edit rights are not granted, so we'll see what we can do for a future release.
Edited by Softrak Support (07/14/06 03:48 PM)
0 registered (), 172 Guests and 3 Spiders online.
14577 Topics
