Page 1 of 3 1 2 3 >
#71434 - 02/18/25 12:40 PM MSVCR110.DLL error
Howard S.-MMA Offline
Maestro
Loc: New York City, NY USA
Hi:
I am trying to do an upgrade at a client. They have 2016-2018 versions but are on support plan.
I started with GridView 93B-20190118 and get this error, then the install stops and exits.
I tried running the installer as Admin but get the same thing.
I ran the GL 93B-20231109 installer and I get the same error. The G/L install finishes but when I try to start Ledger, it wants to do w/s install.
When I do that, I get the MSVCR110.DLL error again, the install finishes but when I try to start Ledger, it wants the w/s install again.
I am logged in as the user who will run Adagio but have full admin rights
Chksys is showing these 2 errors:
========== Checking 32-bit (and higher) System Status ==========
*** Install corruption error, missing: \\oaksrv1\data\Softrak\system\win32\msvcp120.dll
*** Install corruption error, missing: \\oaksrv1\data\Softrak\system\win32\msvcr120.dll
The 2 missing files are NOT in c:\windows\system32
The workstation has Windows 11 Pro, 24H2
Howard Schell
Micro Management Associates
New York, NY USA
bpforum2021@hnyc.us
#71439 - 02/18/25 03:40 PM Re: MSVCR110.DLL error [Re: Howard S.-MMA]
Howard
User does not have enough rights to c:\windows
If I had a dime for every time IT told me that the user has full admin rights only to find out they didn't, I could afford to retire.
#71440 - 02/18/25 05:36 PM Re: MSVCR110.DLL error [Re: Douglas Dickie]
Maestro
I switched to another workstation and was able to install with no problem.
So, yes, probably rights. This workstation was the guy in the company who manages the network.
Yes-A lot of dimes!
Howard Schell
New York, NY USA
bpforum2021@hnyc.us
#71458 - 02/25/25 08:35 AM Re: MSVCR110.DLL error [Re: Howard S.-MMA]
Maestro
OK - So I finally got all their workstations running.
After the problems with the initial install workstation (Windows 11, Version 24H2, Build 26100.3194) noted above, i.e the Adagio Installer error message;
"The file 'c:\windows\system32\MSVCR110.DLL' could not be opened. Please check that your disk is not full and that you have access to the destination directory [OK]"
MSVCR110.DLL did exist in c:\windows]system32.
As noted, we gave up on this workstation and I did the Adagio upgrade from a different Windows 11 workstation with no issues.
I then did the ALLWKST workstation install on 5 other workstations (Windows 10 and Windows 11), also with no issues.
The original workstation that I tried to install from that got the error still displayed the same 'MSVCR110.DLL could not be opened' error when trying to run the ALLWKST workstation install.
I showed the client's outside IT company how to run ALLWKST and let them try to resolve the issue and get Adagio installed successfully on that workstation.
I got it second hand, but they 'updated/copied' MSVCR110.DLL from another Windows 11 workstation.
Then, when they ran ALLWKST again, it gave a similar error message, but this time the error was about a different msvcr/msvcp DLL in c:\windows\system32.
They updated this DLL and ran ALLWKST again, and once again, it complained about another DLL
After about 5 iterations of doing this, the ALLWKST workstation install completed successfully.
I know this is not the best explanation, I have notes scratched everywhere after several days, but I wanted to let tech support and other dealers know of the solution (updating the DLL's in c:\windows\system32) in case they run into this error message.
It seems that perhaps the Adagio install needs to be updated to work with the latest versions of Windows 11-24H2 without getting these errors and having to copy DLL's from other machines.
It did not seem to be a rights issue on the original workstation.
Howard Schell
New York, NY USA
bpforum2021@hnyc.us
#71488 - 03/05/25 11:48 AM Re: MSVCR110.DLL error [Re: Howard S.-MMA]
We have another report of this issue happening on version 24H2 Build 26100.3323.
I have 24H2 but my build is 26100.1 and I don't have that problem.
Does Adagio copy these files to another location and it is not finding them? Some of files are not on that location.
Softrak should find out if those files have changed by the windows update.
#71490 - 03/05/25 12:11 PM Re: MSVCR110.DLL error [Re: Patricia B.]
Hello Patricia,
Look at the Softrak\System\Win32 folder.
Adagio tries to install the files to this folder as well as the Windows folder. You can also check the install log.
#71491 - 03/05/25 12:18 PM Re: MSVCR110.DLL error [Re: Softrak Support]
What do you mean on trying to install? Is it copying from c:\windows\system32 to Softrak or the other way around?
#71492 - 03/05/25 12:34 PM Re: MSVCR110.DLL error [Re: Patricia B.]
Check the install log.
#71602 - 04/08/25 03:29 PM Re: MSVCR110.DLL error [Re: Softrak Support]
Rebecca Young Offline
Loc: Toronto, ON
I just got a new computer and am running into the same problem. I can't load any of the Adagio modules. It's Windows 11 Home 24H2 build 26100.3624. I have full admin rights so I don't believe it's that. I've copied the MSVCR110.DLL from another working Windows 11, but that doesn't change anything.
Rebecca Young
J.R. Jacob & Associates
#71603 - 04/08/25 10:28 PM Re: MSVCR110.DLL error [Re: Rebecca Young]
I found that Windows 11 has now a security feature that doesn't allow to save files in that folder during an installation unless it is a "trusted installer".
Page 1 of 3 1 2 3 >
1 registered (1 invisible), 151 Guests and 1 Spider online.
14625 Topics
