There are a couple of reasons why some of your reports work great and the third one does not complete:
- Your computer does not have enough conventional memory. Depending on the complexity of the report, more conventional memory may be required to allow the report to print. Simpler reports would be OK, but more complex reports may not complete.
Typically, we suggest a minimum of 530K free conventional memory to start, and as much as 580K for very complex reports.
- The links on the report are incorrect. If you have fields from manmy different locations on the report, then there are many more ways that they can be related, and a greater chance they are not set up the ideal way. When the report is open, go to the Edit menu and choose Links, and make sure that the Driving file, the File relationships, the linking Fields, and the Link Mode are all set up in an expected way.
Unless your report requires otherwise, the driving file will usually be a detail file, such as OELINE or ARTRANS. Link files and fields are determinate on how the data is related, and that usually comes with experience.
Quik Reports will attempt to set the links up correctly, but sometimes it doesn't get it the way you need. One way to start is set the default links back and start from there.
Hope this helps.
