#68792 - 10/17/22 04:35 PM Automated Dept Import
FX 9.3B 210325 has the option to automate Department import.
GL 9.3B 220504 doesn't have this option
Is there a reason for not enabling automation of Departments import in the GL?
We cannot import batches for those departments in an automation because there isn't a department import option.
#68793 - 10/17/22 05:15 PM Re: Automated Dept Import [Re: Patricia B.]
Patricia
Good question, that option should exist.
In the mean-time, you can use the department import on start up.
#68794 - 10/18/22 07:50 AM Re: Automated Dept Import [Re: Douglas Dickie]
Hello Patricia and Doug,
I have added suggestions to the wishlist to update Automation with more Nouns for the Import Command for both FX and Ledger.
#68795 - 10/18/22 08:53 AM Re: Automated Dept Import [Re: Softrak Support]
Thank you support. The autoimport was not a solution as required confirmation to do the import at login. Furthermore, in this GL version 9.3B 220504, the Process Imports in the User Preferences doesn't trigger the templates that have auto-import at start up.
#68798 - 10/18/22 09:59 AM Re: Automated Dept Import [Re: Patricia B.]
Hello Patricia,
Yes, you are right. Some of the imports set to 'Auto-import on startup?' are not behaving as they should. I have forwarded this issue to R&D.
#69815 - 05/23/23 11:59 AM Re: Automated Dept Import [Re: Softrak Support]
Hello Patricia,
This has been fixed in the Adagio Ledger 9.3B (2023.05.18) Service Pack just released.
