#67005 - 10/14/21 03:18 AM Customizable Report for specific, ordered SKUs
LCH Offline
Stranger
Loc: B.S.B, Brunei Darussalam
Hi, I’m wondering if I could extract only specific product SKUs out of the entire database and print a report for only specific items based on their exact product SKUs and in the order that I require them to be in, every single time?
It would be great if this function could be saved so every time I needed to reprint the report with updated quantity/cost, it could be done again with just a click.
The report would have a heading like this:
| Product SKU (in the order I want FIXED) | Stock (quantity on hand) | Cost Price |
Or refer to the PNG file I uploaded.
Note that I do understand that ‘Quick Reports’ allows you to extract items based on their stock, date and many other variables, but I currently only need to look at fixed items rather than my whole database, and also in the order that I require them to be viewed in.
Thanks in advance. Best regards.
Edit: I am using Adagio IC, and by “SKU” I meant “item number” in Adagio, which refers to my product unique identifier. Hope that makes it clearer
Description: Would be great if out of the tens of thousands of SKUs in the database, I only want to extract the report of the specific 2000-3000 items in one click, daily.
Edited by LCH (10/14/21 03:23 AM)
Edit Reason: Further Clarification
#67007 - 10/14/21 08:41 AM Re: Customizable Report for specific, ordered SKUs [Re: LCH]
Hi Lee
The answer is yes.
Since you are my client, email me this question and I will answer it in detail - steve@sschwartzcpa.com.
You don't own Adagio GridView, which is the program that would meet your exact request. GridView is sort of like the Adagio equivalent of Quik Reports, and it has the ability to automatically send the output to Excel.
Steve Schwartz
#67009 - 10/14/21 09:55 AM Re: Customizable Report for specific, ordered SKUs [Re: Steve Schwartz]
Lee:
Steve's solution is the most recommended. I would have said to put those items in a Report Group. Create a filter with that group and select the fields you want to see but for some reason the Costs are not showing on the grid. This must be a glitch.
#67010 - 10/14/21 12:25 PM Re: Customizable Report for specific, ordered SKUs [Re: Patricia B.]
Patricia: You're looking at the "Item Maintenance" or "Item Inquiry" grids? Are you logged in as a user with rights to see the Cost fields?
#67013 - 10/14/21 12:37 PM Re: Customizable Report for specific, ordered SKUs [Re: Bruce Gardner]
Items inquiry using SYS on sample data.
#67014 - 10/14/21 01:18 PM Re: Customizable Report for specific, ordered SKUs [Re: Patricia B.]
Patricia:
Make sure that either there is no security groups, or if security groups exist then make sure SYS is assigned to one with rights to see costs.
#67016 - 10/14/21 02:04 PM Re: Customizable Report for specific, ordered SKUs [Re: Douglas Dickie]
It is sample data. It works for the regular grid but not for filter. The cost fields are shown on the grid without filter but not on the filtered records.
#67017 - 10/14/21 02:13 PM Re: Customizable Report for specific, ordered SKUs [Re: Patricia B.]
Hi Patricia,
If as SYS in sample data I select a Filter on the Item Inquiry screen, I can use the column editor to see Cost fields for inclusion as desired. Filtered grids have their own set of saved columns. I cannot replicate a problem just seeing cost fields.
Some Cost fields like Average Cost are calculated in memory and not stored in the data. Is this your concern, that Average Cost shows 0.00 on a Filtered grid but not on the grid with no Filter. I do not know if these calculated fields can display information on filtered grids, but I can aske R&D.
If you have other concerns or information, maybe let's start a new thread with some more specific information and not hijack this thread about custom reports.
#67018 - 10/14/21 02:18 PM Re: Customizable Report for specific, ordered SKUs [Re: Softrak Support]
If my solution works for you, I am glad. I am not interested in the issue for the filters at the moment.
#67020 - 10/14/21 11:52 PM Re: Customizable Report for specific, ordered SKUs [Re: Steve Schwartz]
LCH Offline
Stranger
Thank you Steve, I will send you the email later. Also thanks Patricia, Douglas, Bruce and Softrak Support for your quick replies and suggestions! 👍
Best regards.
1 registered (Howard S.-MMA), 220 Guests and 1 Spider online.
14672 Topics
