Hi Chris,
Which module are you referring to, Adagio Payables or Adagio Checks / Quik Check for Windows?
In either program, you need to edit the check specification to insert your Company Name onto the check. In both cases, the company name field can be found in the spec list, in the Company Information section. Adagio Payables has the code M04 for Company Name. Adagio Checks or Quik Check for Windows has no codes, but Company Name is the first field in the list.
Whichever program you use, simply drag the Company Name field from the spec list to the location you want it to appear on your check. You can format the field for font, size, specific positioning, etc. Make sure you save the changes before closing.
Warren Flett
Softrak Support
