#66235 - 05/31/21 10:39 AM Ledger Update Q
Hugh Offline
Loc: Victoria, BC Canada
I just did the latest ledger update to 9.3B. Everything seems to be working and the version shows as 9.3B however.....
I get an error message that the file "...\x64\LedgerFinRep64.exe is not a valid previous version and could not be upgraded"
Any thoughts on how to fix this?
Thanks!
Edited by Hugh (05/31/21 11:04 AM)
Edit Reason: remove superfluous letter d in body of post
#66236 - 05/31/21 10:55 AM Re: Ledger Update Q [Re: Hugh]
Hi, Hugh,
We didn't install an new LedgerFinRep.exe (32-bit) not LedgerFinRep64.exe with this service pack.
Try drilling down to the folder in your post and (a) confirm that the folder is of exactly the same name as in your post, (b) confirm that there is a LedgerFiRep64.exe in that folder and (c) if it exists, confirm that its Properties, Details show the program version as being 2.1.8.2761.
#66237 - 05/31/21 11:11 AM Re: Ledger Update Q [Re: Softrak Support]
Hugh Offline
OK, found it! I may have typo'd the path name but I had a screen shot of the actual error so I got there anyway.
BUT my version is 2.1.8.2751
Regarding this update, my IT manager is recalling that this problem existed on the previous ledger update so I guess this problem may have been around for a while...
Edited by Hugh (05/31/21 11:32 AM)
#66238 - 05/31/21 11:55 AM Re: Ledger Update Q [Re: Hugh]
Support: I had a client with the same error message last week. I didn't have time to really delve into the issue.
#66239 - 05/31/21 12:28 PM Re: Ledger Update Q [Re: Bruce Gardner]
Hi, Hugh/Bruce,
LedgerFinRep64.exe #2751 should have been installed by the original by the original upgrade to GL9.3B. The 2 prior SPs each installed new FRs but this one did not.
Let me take a closer look and get back to you.
#66240 - 05/31/21 01:43 PM Re: Ledger Update Q [Re: Softrak Support]
Hi again,
So we have duplicated that the GL9.3B(210527) SP does not recognize the original upgrade's FR (i.e. #2751) as being valid. When it tries to install the x64 version is stops.
Have reported to R&D for you.
#66255 - 06/03/21 01:28 PM Re: Ledger Update Q [Re: Softrak Support]
Hi, all,
We've uploaded a slipstream of the GL9.3B(210527) SP that resolves the issue reported. Please download the SP again and install it.
And, thank you for bringing this issue to our attention.
#66261 - 06/07/21 10:30 AM Re: Ledger Update Q [Re: Softrak Support]
Hugh Offline
Updated service pack worked perfectly! Thanks everyone!
1 registered (Brian Stief), 250 Guests and 1 Spider online.
14617 Topics
