Hi Set Lan,
I believe UniDevCo IR (DOS) installs tables for the old Quik Reports for Windows (QRW) product. At least the 6.5A version did. IR 7.0 may not be though, as a there was a data structure changes for 7.0 and I don't think UniDevCo updated the QRW tables.
The QRW table for IR DOS should work with Crystal Reports for Adagio. You may need to select the database using the "ADAGIO.SSI" method, rather than selecting the global file IRGLOB.dat.
I believe Purple was planning for their Windows IR product to install tables for Crystal Reports for Adagio, but you need to check with them. The existing QRW table for IR DOS should work on Purple IR too as it uses the same data structure.
Regards
Steve Wilson
SOFTRAK SYSTEMS
