#62903 - 01/24/20 08:17 PM 2nd Page Header - O/E Specifications
JWH Offline
John Hancock, CPA
Loc: London, ON
Simply when a 2nd page header is inserted into any of our specifications it is completely ignored in the resulting print job (conf, invoice etc.).
Must be missing something obvious but nothing happens for lack of an explanation.
John Hancock
John W. Hancock & Assoc. Ltd.
#62904 - 01/27/20 09:50 AM Re: 2nd Page Header - O/E Specifications [Re: JWH]
John,
Would you zip and email one of these problem specs to TechSupport@Softrak.com please?
Also include both the version and release date of OE you are using.
Edited by Softrak Support (01/27/20 09:52 AM)
Edit Reason: added info
#62911 - 01/29/20 03:05 PM Re: 2nd Page Header - O/E Specifications [Re: Softrak Support]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks will do that tonight.
Appreciated.
John Hancock
#62922 - 01/31/20 10:01 AM Re: 2nd Page Header - O/E Specifications [Re: JWH]
Hi, John,
Received your spec and your email. Have replied explaining how the process should work.
Your spec worked well and all pages printed. The issue was twofold:
(1) there must be enough items in the document being printed to 'require' a second page and, therefore, the 2nd page header, and
(2) in specifying those spec objects that should print on the first 'copy' only, those that should print on the second 'copy' only and those that should print on both. Once this is done, I think you'll have the spec that you want.
0 registered (), 68 Guests and 2 Spiders online.
14655 Topics
