#622 - 06/30/00 03:48 AM QRW 6.2B & Cross-tab reports
The QRW help file implies that Cross-tab reports can be created from other reports: "The following instructions assume that you are building a cross-tab report using a database file as your data source. If you are using a Dictionary or a Report as your data source, the steps you need to follow to call up the Cross-tab dialog box will be somewhat different" yet does not specify how to do so.
Can a cross-tab report be created from a regular listing report? What I want to do is be able to sort from top to bottom on the totals column. I thought I had a workaround, but it causes a GPF.
Thanks for any help!
David
#623 - 06/29/00 08:59 PM Re: QRW 6.2B & Cross-tab reports
Hi David,
You are unable to create a new cross-tab report from a listing report, only from another cross-tab report.
You cannot sort by the total column because the Top N / Group Expert is disabled for cross-tab reports because there aren't any actual groups. Perhaps a better solution for the report you are writing is to create formulas for each of your columns (for example: if Location Code = "A" then Invoice Amount else 0), and another formula totalling each of these to get a total for the row. You would then subtotal each of these formulas by whichever field you require (ie the 'row' field you had in your cross-tab) and hide the detail section. This would duplicate for the most part a cross-tab report.
Then, to sort by ascending (or descending) totals, use the Top N / Group Expert, and choose Sort All and the sum of 'Total' formula.
The Help files are only suggesting that the steps for creating a custom cross-tab report listed below the sentence you are quoting would be different if you were to make a cross-tab report based on either a dictionary or another cross-tab, rather than the accpac.ssi database.
This won't exactly duplicate a cross-tab as you have to know beforehand how many columns will be created, but otherwise this is the direction to take.
1 registered (Howard S.-MMA), 103 Guests and 2 Spiders online.
