#61615 - 08/14/19 09:44 PM
Re: Financial Reporter won't Export to Excel
[Re: Hugh]
Financial Reporter is a separate EXE.
#61616 - 08/15/19 08:59 AM
[Re: Retired_Guy]
Hi, Hugh,
Yes, it's a separate exe and, depending on what version(release date) of Ledger you are using, determines the file being used for the FR.
It's possible but no guarantee that something went awry in your install of the product if, for example, you recently installed an update to Ledger.
Please run the FR and select Help | About from the menu. There should be a number of items listed on the System Info tab. I'm interested in knowing the Path/Name and Version for at least ...LedgerFinRep.exe and, as you didn't say earlier what version(release date) of Ledger you are running, I'd like to know that also along with the ssi2xl being used.
I've tested this using the current shipping version of Ledger9.3A(190720) and FR 2.1.8.2653 which uses LedgerFinRep64.exe. The ExcelDirect from multiple places in the FR is working for me when I run Ledger over a LAN from the server.
What has changed on your system between when the function last worked for you and now? Is there someone else in your office that can run the FR and see if the ExcelDirect works for them from their computer?
Let me know please.
Edited by Softrak Support (08/15/19 09:09 AM) Edit Reason: finished sentence
Regards, Softrak Tech Support
#61618 - 08/15/19 11:45 AM
[Re: Hugh]
Sorry, Hugh, my error. Seems I wrote down the numbers I was seeing elsewhere rather than the 2645 which I'd wanted to. You have the correct FR version numbers. However, it's still possible that you aren't running the correct file or a supporting file or that it's missing.
Specifically, what is the full Path/Name and Version of the ssi2xl listed on that System Info tab? What is the full Path/Name and Version of the LedgerFinRep listed on the tab?
Originally, I suspected that an issue was encountered during an install but, based on what you're saying about the issue working before lunch but not after, that would only be possible if someone had installed the Ledger SP over your lunch hour.
It could be that an antivirus update has mistakenly quarantined a necessary FR file. While I haven't had anything reported elsewhere, it's possible. You'd need to check the quarantine and also your antivirus exclusions to ensure that all things
Looking forward to receiving this information from you.
#61619 - 08/15/19 01:35 PM
[Re: Softrak Support]
Loc: Victoria, BC Canada
Thanks for working with me on this. My IT manager has now resolved the problem which was an incorrect registry entry. He worked with the document below to find the source of the excel direct launch instructions and did a copy/paste to get the correct information in the registry (all beyond my pay grade) working with excel direct The reason the registry entry was corrupt is another matter, but unless it happens again I don't see doing any more work on that piece of the puzzle. Thanks again!
1 registered (Prasanth),
94
Guests and
Spiders online. |
14590 Topics
