#61086 - 06/06/19 06:20 PM Printing cheques
CDCPG Offline
Casual
Loc: Prince George, BC. Canada
Wondering if there is a way to have cheques printed in reverse order? Seems silly to have to resort my cheques for printing every time. Not sure if Adagio will print in reverse order or if there is another way to deal with this issue. TIA
#61091 - 06/06/19 06:31 PM Re: Printing cheques [Re: CDCPG]
Hi CDCPG,
Manual check batch or System Check run?
There aren't any options in System Check Processing to modify the print order. When you say reverse order, do you mean by check number vendor number, or what other information in reverse sequence?
#61092 - 06/06/19 06:59 PM Re: Printing cheques [Re: Softrak Support]
If I may say so, get a printer that prints on the top of the sheet, so you can feed the check stock in face-up. Your current printer may do that using the manual tray.
#61096 - 06/07/19 10:41 AM Re: Printing cheques [Re: Steve Schwartz]
Hello:
Steve's right - you can probably use the manual feed tray if you don't process too many cheques at the same time.
It's not unusual for printers to draw paper in such a way that you need the highest numbered cheque at the top of the tray. My relatively new HP LaserJet M426 does that.
It won't help you at the moment, but most forms printers can put them in reverse sequence if you request when ordering. Or Adagio can print to blank cheque forms (available through your dealer) so there are no pre-printed cheque numbers and they can't be in the wrong sequence. And as another solution, Payables can send EFT files to your Bank or Telpay, thus obsoleting the entire cheque printing problem.
#61105 - 06/07/19 03:37 PM Re: Printing cheques [Re: Bruce Gardner]
CDCPG Offline
Casual
Thanks for the feedback. I will see about using the manual tray, but usually there are too many cheques. Next time I order I will get them printed in reverse order.
#61108 - 06/07/19 04:40 PM Re: Printing cheques [Re: CDCPG]
Don’t order cheques. Use blank stock and the problem disappears. Contact your Reseller.
0 registered (), 164 Guests and 3 Spiders online.
14651 Topics
