Previous Thread
Next Thread
Print Thread
M
MER
Offline
M Offline
I have a dept for reallocation accounts, with 29 expense accounts. The % allocation is changing for the new fiscal year. Is there a way to export the Account Info including the reallocation info so that I don't have to edit each account individually in the Edit Accounts section?
What you want is under File>Imports>Account Reallocations. There should be an example of the layout in the sample data C:\SOFTRAK\Ledger\samdata\GLREALIM.xlsx that matches the default import template.
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
Dan is correct if all you want to do is change percentages of existing reallocations.
It's more complicated if you want to delete a reallocation in total, or delete a detail from a reallocation.
Also, be careful when you are importing that all of the details of a reallocation are grouped together in the import file. If they are not, the import will fail because it will think the reallocation percentage doesn't total 100.
Hi Steve,
I believe that when a reallocation for an account is imported, all the existing reallocation records for the account are deleted prior to the import being processed. So, all reallocation imports must sum to 100% and if you just want to change a couple of entries, the entire reallocation must be imported.
M
MER
Offline
M Offline
Thanks all. It was more complicated to do it simply (ha ha) than I thought, so I edited the accounts individually. It's on my list of things to review with our consultant when we meet with him.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
