#60156 - 02/22/19 02:47 PM error converting datapath to UNC, error code 1217
Luc Offline
Casual
Loc: Ontario
when I try to run any report in AP I get this error
Unknow database connector error..
#60157 - 02/22/19 02:56 PM Re: error converting datapath to UNC, error code 1217 [Re: Luc]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
Hi Luc,
I suspect this could be the same error you had in September. Check your log in path to make sure the slash is not backwards.
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#60158 - 02/22/19 03:08 PM Re: error converting datapath to UNC, error code 1217 [Re: Dan_Desautels]
Luc Offline
Casual
Loc: Ontario
Dan,
the slash was correct, I cleared the data patch, then pointed to the same file and it works
Thank you,
