#5903 - 05/03/06 05:33 PM data integrity check in payables
Holquist Offline
I got a weird access violation when I was posting a manual check. So, I did a data integrity check and it showed 8 errors where computed balance does not match stored balance on two vendors. I did a backup and then told it to rebuild and it indicates that it fixed the 8 errors. But, when I run a data integrity check again the same 8 errors come up.
#5904 - 05/03/06 10:46 PM Re: data integrity check in payables
Cycle through rebuild and recheck until the errors go away. Sometimes it can take three cycles.
If they still don't go away, let us know.
#5905 - 05/04/06 11:18 AM Re: data integrity check in payables
Holquist Offline
I cycled through about 10 times and they are still there. The two vendors that have the 8 errors (4 errors each) are two vendors which have appeared on my open payables report since 2003. They each have an invoice and then an adjustment was made to reverse the invoice but instead of "going away" 3 years ago, they continue to be on my open payables report showing the invoice and the adjustment and a zero current amount. Any suggestions??
#5906 - 05/04/06 12:52 PM Re: data integrity check in payables
Hello Holquist,
Could you ZIP up and send me the data to look at?
0 registered (), 198 Guests and 2 Spiders online.
14666 Topics
