#57930 - 07/03/18 04:00 PM AdagioV2PDF not found
Fong Offline
Adagio Ace
HELP!
One of user's new computer (Windows 10) on our network don't have the AdagioPDF and the AdagioV2PDF printers in Devices and Printers. How do I get the printers?
I tried uninstall and reinstall Softrak/system/AdagioPDF/adagioV2pdf.exe, but had no change.
And, I don't see Adagio Accounting PDF Printer Softland in "Programs and Features".
Below are the results of GetInfo:
Adagio Workstation Information [as of 07/03/2018 1:21:24 PM]
Run from [M:\SOFTRAK]
User: [jthai] Logged into [\\DC]
as Admin. [False] with UAC Enabled [1]
on Computer Name [K2DEKSTOP-JULIE] Windows Version: [6.3.17134] Processor: [Intel64 Family 6 Model 158 Stepping 9, GenuineIntel]
Adagio Mapped drive: [M:]; UNC: [\\K2-ADAGIO-SVR\Company Shared Folders\Adagio];
Adagio Payables 9.3A (180201) === Company: [K2 CORROSION FASTENERS INC.]
Wkst Version OK: [True]; Registry [20140733]; {must be >=} Main [20140733]
Report Tables Status: Result is OK: [True]; {Is Eval. version: [False]}
Report Tables drive: CU Registry [M:\]; CU UNC [];
LM Registry []; LM UNC []
Resources: Flags [CIXM9wR8D]
Web storage Exe: []
PDF Version 8 must update: [False]; Nova8 File Ver: [8.7.943.0] must be >= SysComponents: [8.7.943.0]
Crystal Scheme OK: [True]; Reg. [13.0.20] must be >= Min. [13.0.16];
dotNET Scheme OK: [True]; Reg. [461808] must be >= Min. [378389];
ODBC Component Path: [\\K2-ADAGIO-SVR\Company Shared Folders\Adagio\SOFTRAK\ODBCV2\AdagioODBCv2.dll]
ODBC Component Scheme OK: [True]; File. [2.1.8.199] must be >= Min. [2.1.8.189];
--- NOTE: ODBC Component is in a different Softrak Folder!
System Files: Components: [INST PRGR CR_13.0.16 DN_378389 OD_2.1.8.189 PDF_8.7.943.0]
No QRW Files.
----- Registry Trace: -----
HK_LMx64: [Software\Softland\novaPDF 8] {Default:}; exists: [True];+Opened;
. .Key: [DriverPath] exists: [True] Value: [C:\Program Files\Softland\novaPDF 8\Driver]
HK_LM: [SOFTWARE\SAP BusinessObjects\Crystal Reports for .NET Framework 4.0\Crystal Reports\] {Default:}; exists: [True];+Opened;
. .Key: [CRRuntime32Version] exists: [True] Value: [13.0.20]
HK_LM: [SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full] {Default:0}; exists: [True];+Opened;
. .Key: [Release] exists: [True] Integer Value: [461808]
HK_LM: [Software\ODBC\ODBC.INI\Adagio Data Source] {Default:}; exists: [True];+Opened;
. .Key: [Driver] exists: [True] Value: [\\K2-ADAGIO-SVR\Company Shared Folders\Adagio\SOFTRAK\ODBCV2\AdagioODBCv2.dll]
***** Adagio Payables STATUS: OK - NO Workstation Update Needed. *****
#57939 - 07/04/18 10:02 AM Re: AdagioV2PDF not found [Re: Fong]
Fong Offline
Adagio Ace
I ran the batch file ‘ReinstallAdagioPDFx64.bat' and it works!
