#5771 - 03/30/06 11:55 AM Error Message /t
I receive the above error message as a pop up information window when I open the time & billing module from the Adagio Pull Down menu when I am in any other module. I have not noticed any change in the way the Time & Billing module works if I were to continue on by selecting the "ok" button but then again, I have been reluctant to enter any information in the Time & Billing after such an inauspicious opening. I've been closing the module and opening the TB module from scratch and re-entering my password to be on the safe side. We did a data integrity check to see whether that would make any difference. It didn't.
Please advise.
#5772 - 03/30/06 12:39 PM Re: Error Message /t
Hi Robin,
There is absolutely nothing to worry about if you are opening Adagio Time&Billing from another Adagio program and getting a /t error message. The reason is that if you start Time&Billing version 6.5 from another program, a /t parameter that gets sent to maintain the sign-on date is not recognized - because T&B6.5 is an old version that doesn't recognize the feature.
If you start Time&Billing from a shortcut, rather than from another program, you should see that all works OK.
The Time&Billing 8.0A upgrade allows this date parameter to be recognized, so the error will no longer occur after installing the upgrade.
