Hello KBK,
The error, "The file 'd:\QRASP\QRTABLES.INI' could not be found." is described in the QRW 62B Users Guide in Appendix A.
If the QR tables have been installed, this error message means that the CRW.INI file has not been updated with the correct path to the QRASP.
In QRW, create a new custom report. On the 'Select program for report' screen, choose the 'Edit Company' button.
In the section 'ACCPAC' programs, choose the Browse button. Open up a program directory (ex: ARASP, APASP, GLASP) and choose any file that ends in the extension LD4.
This will update the ACCPACPath= line under [ACCPAC.DLLInfo] section of the CRW.INI file. The CRW.INI file is located in the Windows directory.
