#5672 - 02/22/06 09:01 PM Re: Printing problem
Hello LDroine,
Tech support will have better ideas, but first check that you user has complete r/w access to their Windows\temp subdirectory (check temp= in their environment). We're assuming that there is something there to print! Also, run softrak\system\chksys.exe and make sure that their dictionaries are all properly installed.
#5673 - 02/22/06 10:29 PM Re: Printing problem
Does the same thing happen when you simply try to preview the reports instead of printing them?
Does it happen if you try to print to a different printer on the network?
Does it happen with sample data?
I don't work for Softrak, but every time I report a similar problem they ask me these questions, so let's get them out of the way first.
#5674 - 02/23/06 11:29 AM Re: Printing problem
Hi Linda,
In addition to all the good comments already posted, try printing the Company Profile report - which does not require a work file. This can help point out if the issue is with the local temp directory or maybe a table problem.
Perhaps also log into the machine as the Admin (not the user) to identify whether rights is indeed a culprit.
Reports that require work files are typically the batch listings, posting journals and transaction reports. Those such as Terms Code list and other general reports do not require a work file.
#5676 - 02/24/06 10:38 AM Re: Printing problem
Ralph Allan Offline
Check to see if they have installed any other programs that use Crystal Reports. Perhaps there is a version conflict with two sets of Cyrstal run-time files.
3 registered (AudreyQuick, Howard S.-MMA, Bruce Gardner), 250 Guests and 3 Spiders online.
14589 Topics
February
