Hi Michelle,
There was a problem converting Quik Check for DOS data when the data extension was only 2 characters instead of the full 3. This has been fixed in Adagio Checks.
If you rename the data extension for the QC data files from 'kc' to 'kc1' or any 3 characters, then you can coonvert the data succesfully, then rename the extensions back if you wish.
All versions of Quik Check for Windows and Adagio Checks uses the same data structure, so there is no data coversion necessary. It is only when you point either at a Quik Check DOS database that conversion is necessary. It is looking at the qcglob.dat file and determines what must be done.
