#5371 - 11/10/05 11:53 AM Problems entering time in T&B
Holquist Offline
Since installing the program on my new laptop, when I go to enter the client and then the matter i can't enter the matter unless i go past the field and come back into it...when i tab to that field it highlights the box for a lookup rather than putting the cursor in the box to type the matter no. Any ideas? It will not let me type over the matter that is currently in the box (unless I have changed client numbers, then it will). So, i have to either go back and forth in and out of the box or put the cursor there myself before it will allow me to enter the matter no. and that has never happened to me before. Please let me know how I can fix this as it makes time entry extremely slow and cumbersome. Thanks!!
#5372 - 11/10/05 04:11 PM Re: Problems entering time in T&B
Hi Sherri,
Though I see the cursor missing when doing entry from a TimeKeeper button, things seem to be holding together OK when entering a Time batch.
What version is installed on your laptop? There was a known issue in an older release, but was fixed and should be working in the current release. Below is from the release notes of the Nov 2002 release.
quote:
The Docket field was skipped in some cases when tabbing through the fields entering a T&D batch.
Who knows, maybe if an older version is there, then that is the cause of the 0.1 problem, too.
#5373 - 11/14/05 10:41 AM Re: Problems entering time in T&B
Holquist Offline
Thank you so much. With all the reloading of all the software programs that I had to do, I forgot to load the update for T&B. Once I did that, the problems went away. Thanks for letting me know. Have a great day!!
0 registered (), 265 Guests and 3 Spiders online.
14668 Topics
