#5356 - 11/07/05 12:13 PM error:120 Lookup
I am trying to print a report of Vendors transactions for last year and I keep getting a message: ' Error:120 Lookup item not found:: Formulas.Name:=Footer4key"
I did an integrity check and it's fine. I know that this function worked on Oct.12/05 because I printed a detailed one for one vendor and a summarized one for another vendor. Now I want to print the detailed listing for the summarized one, and I keep getting this message. I even tried reprinting the same report for the detailed one that was done on Oct.12 but now I'm getting this message.
#5357 - 11/07/05 12:57 PM Re: error:120 Lookup
Hi KEMLTD,
The situation has to do with the report - your data is fine. From the error message, there is something wrong with how the report is dealing with the 4th sort choice; a problem with the report. This has been reported by one other client where using Vendor Name as the 4th sort on the list caused the problem, but changing this to something else allowed the report to print OK. So perhaps try changing whatever you have in the 4th sort on the Vendor Transactions print report screen.
#5358 - 11/07/05 01:13 PM Re: error:120 Lookup
You're right!! That did it. Thanks for your help!
Diane
