The file from your Payroll software indicates that the code for your payroll bank is "1". However when Adagio looks at the list of banks in the Bank module, it doesn't find a Bank = "1". Therefore there is a mismatch between your Payroll software and your Bank Reconciliation module. Likely you need to adjust the Company settings in your payroll software.
Hi there, thanks for your response. This has only recently started happening, prior to March 2016 payroll entries would be retrieved just fine. We are using PayDirt - do you know where to go in that system to fix this?
